A couple weeks ago i did a drain and fill on my transmission. I also changed the ATF filter. When i went to run it through the gears, I quickly realized I was leaking fluid due to being double gasketed at the filter. I immediately pulled back into the garage, remedied the issue and topped off my ATF. Everything appeared good to go other than the fact that I was reading a bit high on my ATF. The next morning, I drove up to the dealership to have them double check my levels and give me some assurance that I was ok. They said I was a little high, but nothing to be concerned about. Shortly thereafter I realized I was leaking ATF. I took it back in to the dealer and they told me that I was probably leaking excess ATF out of the vent line on the top of the transmission. They did another drain and fill (no charge), checked my levels and off I went.
Turns out the leak is still there and appears to be getting worse. It's leaking right in the area where the tranny and diff connect and/or in the area of the bell housing. Beyond that, I couldn't tell you any more specifically where it's originating from. I left work today and noticed that during acceleration, the car is "chunky". It's as if it burps as it's accelerating. I don't notice any noises. I drove it straight to the dealer and left my keys in the drop box for tomorrow morning.
Anyone have any ideas what I may be dealing with here? Thanks in advance.
WOZ
WOZ
