1 - 2 of 2 Posts
2002 2.5 Auto Legacy Outback
when i put my 2002 2.5 outback into D it will not engage until reving engine then it bangs into drive this only happens when hot not at start up. checked fluid and its spot on and clean
i live on a buget so any cheep fix would help thanks
Sorry, there is not a cheap fix. You have seal leaks within the transmission and it will need to be rebuilt or replaced. Upon tear down of the current transmission you will find burned clutches due to low pressure. The filter is catching the debris.
1 - 2 of 2 Posts
