1 - 20 of 27 Posts
'06 Outback 2.5i
Help, I am confused. I have '06 OB 2.5i with 48k miles. What is the transmission fluid change interval? It has not been done yet and i am not sure if i am due.
Manual maintenance schedule has just " I " every 30K miles which means 'inspect'. This must be a typo, right? It makes no sense that fluid never needs to be replaced. Manual also says that fluid is HP type, does this stuff last forever?
thanks
'14 3.6R Outback
Why?
Other topics on this that I could find:
http://www.subaruoutback.org/forums/66-problems-maintenance/49224-06-outback-auto-2-5i-hard-shifts.html
http://www.subaruoutback.org/forums...anging-automatic-transmission-fluid-easy.html
It's my understanding you only need to worry about fluid changes IF you tow.
If you are really worried look up the Tech manual and you can see exactly what they do when they "inspect." I'd recommend against a change or a flush unless you are having issues or tow.
'14 3.6R Outback
What do you mean, "why?" What, Never? Not even after 300 K?
Do you know the answer or what?
If i needed some flippant, sarcastic response, i'd ask my wife.
Haha, sorry I posted some links, maybe you didn't see them since I was still editing the post and it looks like you posted before I was done.
'06 Outback 2.5i
Thanks, i have read these threads, but still was not clear.
I am not worried, just trying to make sure i'm following the schedule and there is no typo. I have never owned a car that had lifetime fluid of any kind before, but it`s nice.
I am not one to think that there is some conspiracy at Fuji Industries to blow up our transmissions by telling us not to change the fluid. What is their gain from it :rolleyes:
I will leave it alone then. Good to know other people looked into this.
thanks again
thanks again
I have a thread on this subject too, including the AT filter. What you say about the Maintenance booklet is true for my friend's 07 OB 4EAT. It goes up to 120k miles calling for inspection only on the fluid unless you tow. I found a Subaru bulletin that explained the differences between regular Subaru ATF and Subaru HP ATF. Regular is a Dexron formulation for 4EAT 2005 and earlier. HP has a different friction package for all 5EAT and 2006 and later 4EAT. Main point is that neither is synthetic. Even if you do not tow, I can not imagine a non-synthetic ATF lasting 120k miles. My friend's dealer recommends a drain/fill every 30k which makes sense to me. The filter is designed for lifetime service but I would probably change it every 60k miles just for kicks and giggles.
2011 Subie 3.6R Limited 2013 Cmax e=nergi PHEV
Gen 4 Datapoint on HP ATF
I drained about 5 quarts of the HP out after 35k of hard start stop short interval and lots of downshifting mountain driving.
My ATF did not have a tinge of red coloration left. It was a dark chocolate color.
I do not have any idication that the anti-friction or thermal properties had broken down, but it the drained ATF HP looked like crap compared to the pretty new red stuff.
Now my shifts seem smoother, but that is completely subjective.
I don't see any harm in a drain and fill as long as you get the fluid to the correct level.
Tranny repairs are not cheap.
2005 Outback 2.5i
Drained and replaced 3.5 quarts of ATF tonight. I was having trouble with my transmission not wanting to downshift. The ATF that drained out was old for sure.. probably original, but it was not burned or black. I replaced it with Castrol J-spec @ $6.29/bottle from Advanced Auto. Well what do you know, the car downshifts now!
Well worth the $25 and 30 minutes spent.
(EDIT: My OBW has 78K on the clock)
2008 Outback, 2.5i auto
60k check, dealer bait and switch?
Dropped my 08 2.5 i for a 60k check . Got the mid day phone call with "notes from technician". Your car should have ;
1. 260 dollar transmission flush.
2. 100 dollar power steering fluid flush.
3. 100 dollar differential fluid change.
My first question is this necessary first of all?
More importantly why don't they go over this in the am during the drop off?
I stayed with dealer maintenance as I have some coupons to use from the Chase card which are like cash but when the car was new they tried to tell me it needed a "non warranty part" causing a buzzing under the car when cold. I told them no as I knew it was a heat shield that needed a bend. At the time I dealt with a service rep sitting at a divided desk area . When I balked at the "non warranty part " which caused the "exhaust system to be removed" in a half hour another guy was listening behind the wall who then came out and said forget it.
I just don't feel I can trust these people after the first experience when new.
2005 Outback 2.5 XT Limited, 1995 FWD Legacy sedan
These people are just trying to separate you from your money. You can follow the fluid change recommendations in the owner's manual. If I were you, I would find a different (independent) place to have car maintenance done; there's no reason to support a business that you can't trust.
Fresh Out of Outbacks!
I don't think there is an expectation that the fluid will last forever. More likely they couldn't accurately suggest a replacement schedule that fit all driving styles, climates, etc. So instead they have advised us to inspect it every 30k and replace as needed.
This seems entirely reasonable to me.
2013 Outback 3.6L Limited with EyeSight
My Subaru dealer stated that "Subaru ATF-HP was a synthetic." Can anyone confirm that the HP version is or is not a synthetic ATF?
2005 Outback 2.5i
Nobody can confirm that except the lab scientists working at Idemitsu. From my understanding, they are treating it like a trade secret. (a la WD40, Coca Cola, etc.)
The best guesstimate is that it is synthetic (or synthetic blend), which I believe to be true. This is because its minimum "pour point" is -60degC. This is typical of a synthetic. As a comparison, the non-synthetics normally have a pour point of around -50degC.
One would think that if the HP version was a FULL synthetic that it would be advertised as such.
Nothing negative about stating it's a synthetic, but a little turn-off to says it's a conventional.
I agree that the specs lead you to believe the HP fluid is likely a semi-synthetic ATF.
2017 3.6R Limited (Wifes), 2009 3.0R Limited 125k (Mine)
Change the ATF before it becomes discolored, burnt or oxidized. It seems many wait until this point or until the car “does not downshift” any longer. The best thing you can do for your transmission if equipped with a drain and fill is drain it ever 15-20k. I do mine every 15- 20k and manage to get 6 quarts out each time by putting a floor jack under the driver side frame rail and lifting/tilting the car about 6-8 inches. You will only get 4-4.5 Quarts out if the car is left flat or lifted equally from the front. I drain the fluid when it still looks new, smells new and has the same properties it did when it went in. I have been doing this for 200k on my 01 H6 with Mobil 1 one synthetic ATF as well as changing out the spin on filter under in the driver front wheel well area every 50 k. My 09 3.0R is on the same change interval except I use Subaru HP fluid. I measure all fluid after it cools and put the exact amount back in and the levels are always perfect. Once fluid is discolored, burnt and oxidized the damage is already done, don’t wait to that point. If you constantly change out 6 Quarts in a roughly 10 Quart system every 15- 20k the fluid will always be factory fresh and the Trans will live a long happy life. If you plan on keeping the cars over 100k you will be rewarded with a more efficient car that is far less likely to have very expensive transmission issues. Fluid is cheap, repairing a transmission is not.
2009 Outback 2.5i Limited
I drain and fill my trans fluid every 20 to 30 thousand miles. Usually every 4 oil changes. I use the Subaru HP ATF fluid. I heard it was synthetic some time ago. Do not remember the source though. I am about to turn 124,000 miles and I plan on keeping it as long as possible. That would be 300,000 miles or more. I also change my diff fluids every 50,000 miles.
:cool:
This is typical car dealer service. Their techs are no better than the independant garage and a GOOD independant will be much better, IMHO.
This past summer I left my wifes Outback at the dealer we purchased from as there was some kind of recall notice. We were going on vacation for a week and would not need the car. The passenger side front window was non functional so I asked them to look at that as well. Needed a window motor.
When we got back to pick it up, we find out that the car was no longer at the dealership. The car was at the body shop having its rear window replaced and rear hatch and bumper repainted. Seems the mechanic who worked on the car backed into a fence in their parking lot. To add insult to injury, they never bothered to call us and let us konw that there was an issue.
Trust me, my cars will never be in their service bay again, I don't care if the service is free; its not worth damaging my car from careless mechanics.
Now that winter has set in, I find that my rear window defroster dosent work....:mad:
'17 OB 3.6R Touring [ex-'09 OB Ltd. (2009-16); ex-'01 Audi A6 Avant (2001-2009)]; '14 Impreza Sport Premium
As in many things re fluids, "lifetime" is a loaded term... if you never change your ATF, the lifetime of your tranny will almost surely be less than if you do.
I change it every 30k-45k, cheap insurance and it does help keep it shifting crisply, etc.
1 - 20 of 27 Posts
