Hoping someone can give me some insight on this. I don't have a lot of money and cannot afford to keep paying mechanic to keep trying things until this is fixed. My 96 OBW that has trouble in low gears. When I first start the car and start driving, the following doesn't happen. It is only once I stop at a stop sign and take off again.
When I lightly press the gas or even coast slowly it sounds like someone left tool in the transmission! It feels normal then every half second it thuds enough to shake the whole car. People outside of the vehicle can hear it very clearly. It does this over and over and would probably endlessly do this unless I speed up and get into second gear. It is worse when I turn and always happens when I am turning but also happens when I am driving straight at times.
When the car shifts into second gear it will sometimes shift super hard. It feels like it is mainly coming from the rear wheels. Although it is happening at times when the rear wheels should not be engaging (like on dry tar).
One other thing I have noticed is that when it is above 20°F outside, it is much worse.
