My front axle needs to be replaced and my mechanic is charging $370. Does this seem high to you? I am a newb here so be gentle. Also does it really matter if it is genuine Subaru Axle?
Thanks!
Thanks!
Yes considering that the axle will probably cost him $75 or so(if not at the dealership)...and take (including break) about 30min to install.My front axle needs to be replaced and my mechanic is charging $370. Does this seem high to you? I am a newb here so be gentle. Also does it really matter if it is genuine Subaru Axle?
Thanks!
Find out if he is going to use an Remanufactured Axle from Subaru, thats around $200. Whats his shop rate? Around here its around 80 to $90. Book time is more than 30 minutes it might take him. If its a genuine part, 370 may seem like a lot, but he's not ripping you off.My front axle needs to be replaced and my mechanic is charging $370. Does this seem high to you? I am a newb here so be gentle. Also does it really matter if it is genuine Subaru Axle?
Thanks!
