1 - 12 of 12 Posts
2000 OB Auto
Hi,
I have been hearing some noise for like 4 weeks now. Here are some symptoms:
1) The noise is not there when the car is cold, only hot.
2) It is pretty clear not engine sound. At highway speed it is obvious
3) It is also very obvious when I let off the pedal, at reasonable speed (40-50 mph)
4) It is continous.
5) I cannot describe the sound, but like another loud car next to me
6) I cannot identify the location of the noise when driving.
Thanks in advance!
2001 VDC/SC One of a Kind
Depending on the year model, you either have to have a press or it's bolt on. The rear hub assemblies are bolt on for all model from 2000 USDM SOHC models up. Bolt on fronts didn't come around until 2005 USDM.
Pick the wheels up, turn it while holding one hand on the spring. The offending bearing will make the spring vibrate. You may even hear it.
It's obvious because:
1. the reduced engine noise makes it easier to here?
2. or it gets louder when you let off the pedal?
3. is this an automatic or manual transmission?
4. what year/vehicle are we talking about?
If it's very obvious you should be able to tell which corner it's coming from. listen carefully.
Hit the rotor closest to the hub with a temp gun and compare both fronts and both rears. Is one hotter than the other?
2000 OB Auto
Thanks a lot guys!
I will do some of the testing like vibration and temperature. @cardoc, what is the string you are referring to? Is it the suspension big coil spring?
My car is 2000 OB auto. The noise is more clear because the engine sound is less when pedal is released, not the noise is bigger.
Also, checked on this forum, people seem to always replace the hub as well. Is it necessary?
Thanks!
Nah, they don't. They are replaced if the bearings were run bad for an excessive amount of time and damaged the hub or a previous bearing installation pressed them improperly and deformed it.
2005+ bearings include the hub as part of the bolt on bearing assembly, yours is a press fit bearing.
2000 OB Auto
Did a temperature measurement. Not much difference between the two fronts and two rears. Maybe I didn't drive long enough, about 5-6 miles. Will try again.
Having no press this gonna be painful if have to do the front.
I have had some really bad wheel bearings and they never got hot.
Only one ever got loose, and that one was so loud I had to wear ear plugs to drive it!
If it gets quieter and louder on turns, sometimes when the outside one gets quieter, sometimes the inside (happened to me).
Only way I figured out 100% which it ever was before it got loose was to put it on 4 jackstands and pull all 4 wheels and put it in drive and let it idle and check each spindle with a metal rod held to my ear (mechanics stethoscope).
2000 OB Auto
Discussion Starter #10 (Edited)
@CNY_Dave Do you mean to just idle the car? There won't be any rotation though. Maybe someone needs to pedal it to some speed?
edit: sorry you did say put it in drive.
1 - 12 of 12 Posts
