They haven't addressed the battery issue on USA made Outbacks. I can speak for my '17 Outback 2.5i Limited - it came with the wimpy 365cca group 25 battery. Trying to decide if I want to go with an Optima Red Top or save $30 and get the WalMart Everstart Max.
Red Top for sure! And order it direct from Optima! That way you're getting the freshest battery possible, and shipping is free!
The problem with getting them from an auto store is the fact, not too many people want to spend that kind of money on a car battery, so they sit, and sit, and sit...
I've been an impressed customer since 2000. In fact, I purchased a Blue top (Deep Cycle) battery paired up to a LARGE inverter, for location lighting in my photography business back in 2008. Since then, due to my health issues, the business went into the ground, and the inverter/battery setup has sit, collecting dust, and not used since then. Flash forward 7 years.
I needed power out in the yard for some electric yard equipment, i.e. Chain saw and hedge trimmer.
My gas generator needs some work on the carburetor, so I thought about pulling the battery thing out of storage.
Naturally, when I did, the battery was flat as a pancake.
I decided to put my charger on it. Because it's a smart charger, there wasn't enough current to turn it on...
So I grabbed a 9v battery, and tricked it into thinking there was a battery hooked to it, so it would start charging.
I really wasn't expecting much. In fact, I figured there was NO WAY I was bringing a flat, 9 year old battery, that had been stored for the last 7 years.
After a few min I took the 9v battery away, and the charger stayed on! So, I left it to trickle charge for the next 2 days.
I figure the shock of high current charging on such a flat, as well as old battery, would definitely ruin it.
After two days, I unplugged the charger, crossed my fingers, and turned the inverter on. I have to say that for the inverter to work was even questionable, because of the capacitors.
Well, the lights came on, and it started working!
I plugged the chainsaw in and started using it. Between my wife and I, we used it for about an hour, and it was going strong!
I brought it back to the house and plugged the charger back in. It recognized and started charging it automatically!
It took about 2 hours to fully charge it, then it went into automatic trickle charge mode.
I was a fan before, I'm a true believer now!
For a 9 year old battery, to sit 7 years unused and flat, then be brought back to life and work is, AMAZING!
Are Optima battery's worth it? Heck yes!!!
P.S. Just for you doubters. I included some pics of my Battery Thing...
