2005 Outback 2.5XT & 2003 Mercury Grand Marquis
Has anyone used this fluid for the 5eat?
The Beck Arnley site shows it's compatible with a number of Subaru/Nissan/other 5at transmissions.
It can be had quite a bit cheaper than the Subaru HP ATF if you look around.
I'm just wondering if anyone has tried it and noticed anything positive or negative.
Beck Arnley is a supplier to Subaru. Not sure who blends their oils. If BA says its compatible then you can hold them to it should anything occur due to the type of fluid.
Good to know. I'm going to call and double check with one of heir reps to be on the safe side. Thanks for the reassurance.
