Does reconditioning mean charging to full?I recondition them @ twice a year with my NOCO.
These are indeed heavy batteries! The Group 25 PCI 1400 Extreme (which I don't see on the list any more) also weighs 50 pounds. Even the burly guy behind the counter at the parts store commented "man, this is a really heavy battery!"... So, I went through Amazon and requested an Amazon return. They sent me a prepaid slip for UPS and the battery was returned. The battery weighed 50lbs and I dropped it on the counter at UPS with a very large thud. The tiny girl behind the counter couldn't lift it.
Good eye!I did notice from the pictures you included that the corners of the plastic cover under the connectors on your Odyssey battery are also pulled up. That does look like it was mishandled with one of those handles that attach to the connectors in order to lift it easily in and out of the car.
Now we're getting to the bottom of cause here - although this really doesn't concern you directly.And, someone did drop the box/battery on the terminal side, the inside of the box has two indents that are right above the terminals.
I stand corrected, I actually have the Schauer Charge Master CM6A. It has a setting for AGM batteries (Odyssey), and I know that it "reconditons" and "fights sulfation", and to answer your question it does charge to full.Does reconditioning mean charging to full?
I've got a Genius 10 and the "repair" mode on it does de-sulfication (or whatever it's called), but my reading of the manual and research on the unit make it sound like that's only for flooded batteries, not to be used on AGM.I stand corrected, I actually have the Schauer Charge Master CM6A. It has a setting for AGM batteries (Odyssey), and I know that it "reconditons" and "fights sulfation", and to answer your question it does charge to full.
I am certain that someone on this site recommended it, and that is why I purchased it. The Schauer CM6A retails for around $70. I have had it for over 2 years now, and use it on all my car batteries, ATV, and lawn mower. No problems.
You might be right. When I do mine, it goes through the modes of "Bulk", "Absorption", and "Full". That's when mine is on the "AGM & Wet" setting. So apparently the Schauer goes through the same cycle for an AGM as it does a Wet. I assumed it desulfates the battery, but I'm obviously not very sure. All I know is that someone on this site recommended it, and that was good 'nuff for meI've got a Genius 10 and the "repair" mode on it does de-sulfication (or whatever it's called), but my reading of the manual and research on the unit make it sound like that's only for flooded batteries, not to be used on AGM.
I would take it back to any auto parts store that sells batteries. I'm pretty sure they are required to take them for recycling. Last time I did that at AutoZone, they actually gave me a credit for a core charge that I had never paid, since it was a UPS battery.Amazon did a full refund. There's no local stores that has this particular battery in stock, where should I buy it? What should I do with this battery? 😳
That all depends on state laws regarding recyclable products. Some states are required to charge a core charge, and refund it if you take the old battery back with 30 days. Others aren't required to charge for the core, so they won't give you anything back, but will take it off your hands. If all else fails, your local Walmart will take it from you...I would take it back to any auto parts store that sells batteries. I'm pretty sure they are required to take them for recycling. Last time I did that at AutoZone, they actually gave me a credit for a core charge that I had never paid, since it was a UPS battery.
