Good morning everyone! I have been trying to find a good 2 bike platform rack for my 2017 Outback with a 1.25" OEM hitch. I was going to purchase the Thule DoubleTrack Pro 2 but their website said you have to have a hitch with a 1.5" pin hole depth. the OEM hitch has a 1" hole depth.
Is there a 2 bike platform rack that would work with the OEM hitch? I want to be able to lock the rack to my hitch.
Thanks in advance for your help!
1" depth seems awfully short.... You may want to double check your measurements... :unsure:
Even if it is a 1" pin placement, you'd have plenty of shank inserted into the hitch itself to stabilize the rack.
I have a Swagman XTC-4 that has been great... (Heavy, but great) their 2 bike version is XTC-2
Check out etrailers clip on adjusting your Thule. Does the pin placement look similar to yours?
2002 Outback VDC
Oh yeah the OEM hitch has the hole way too close to the end. From my days at the rack shop a lot of people took their Subarus back to the dealer and had the OEM hitch taken off and then installed an aftermarket one. I think the only rack that is certified for it is the "Subaru Thule Helium" which is like a Thule Helium but they modified the insertion part where a bolt goes through instead of the nice quick-release you get with the regular Thule one.
2013 Outback Premium - 6spd manual
I'd also really suggest going with a 2" hitch swap. Factors like the tongue-weight alone are pretty big, when you get 2+ bikes, sitting out a bit, it really adds up, going over bumps/dips and such.
If you do the math, with say a 30lb hitch, and two 30lb bikes, and a 2' extension (to the furthest-back bike), it's pretty easy to get WAY up there, in terms of dynamic forces. If you go to > 2 bikes, you'll almost certainly be way over.
Most 1-1/4" hitches are rated to 300-350, and a comparable class III 2" are in the 600-650 range, for an Outback.
The depth is significantly more, too, completely eliminating the problem with the depth-reach, for locking and otherwise.
