At 50+mph, the back end of my 2002 OBW H6 VDC seems to slide, when it hits a bump, a few inches from one side to the other and back again, I don't know how else to explain it, it is strange. Without hitting a bump it drives and feels perfectly normal.
Had some sagging issues if I had like 500 pounds in the car (like 3 people in the back seat or gear in the back), the rear drivers side would sit so low the tire would rub. I put more weight on the passengers side to make it home without rubbing on a long trip. Without weight in the car it drove perfectly normal.
I installed new struts and springs and i assume that issue is corrected, though I haven't loaded the car since then either. And i haven't driven at highway speeds since the spring replacement but it still seems a bit off in terms of the sliding issue.
I yanked on sway bars and links underneath, nothing obvious. Really isn't much rust to speak of, just standard for here rust, no rotting.
200,000 miles
New rear struts and springs
Front struts are original (hands head in shame LOL).
Anything else to look out for?
Could bushings cause something this drastic?
200,000 miles
