I purchased the kit and the antenna on ebay. The link for the antenna is correct. The neat thing is I can press and hold the green button for 3 second and tell Siri to play music, call, text, etc..
I decided not to go bluetooth, was considering Aux in, and while searching found this Crutchfield endorsed (at twice the price) lighting adapter input that fits my iPhone:
"You can listen to your Apple device through your car stereo simply by connecting the
TranzIt LINK's Lightning connector cable to your iPod, iPhone, or iPad. The cable connects to the main modulator box which you've placed out of sight. You can enjoy your favorite music on the go and keep your newer Apple device charged as you drive. You'll be able to enjoy your favorite
music apps and turn-by-turn navigation directions from the Apple device through your car's speakers, too."
Since I always use a Proclip dock with lightning cable, this might end up being the best option for me
iSimple IS7705 Tranzit LINK iPhone lightning power and audio FM adapter
Antenna adapters
Results:
Today with the help of a friend with a screwdriver, we installed Tranzit Link and I am very happy to report IT WORKS!
We followed
these instructions to get the stereo pulled out of the way
Now when I dock my iPhone to my Proclip, it automatically plugs in the lightning connector that both charges my iPhone and outputs music and navigation to my stereo.
It works perfectly, both music and navigation cooperate, and all the steering wheel controls also work. Since I NEVER listen to radio nor CD, I just keep Tranzit link tuned to the station it uses.
There is no FM audio interference. I am very impressed and highly recommend the system for cars with integrated digital climate control stereos. It does not provide USB connectivity, nor bluetooth, nor Aux input, none of which are needed to accomplish my 2 goals, charging and sound output..
Im very excited about this, took me a long time to understand my choices. Highly Recommended.
special thanks to
@Tin Nguyen for sharing his success, that encouraged me to abandon my prejudice against FM adapters.
the guts
the goal
and the Glory!
No more usb wire plugged into a cigarette lighter adapter in my ashtray. No more listening to my navigation through the iPhone speaker, now I get iPhone audio through the car speakers.. a dream come true!
the only thing the Tranzit kit lacks is a blue splice connector for the power wire, and a ring connector for a ground wire. Tools were, flathead, phillips, pliers and wire crimper..
oh, the antenna wire adapters were a perfect match for the Tranzit system to work in my Subaru, be sure to get those.
Siri works normally, by pressing the home button
the advantages of Tranzit Link over Bluetooth is the link charges the phone at the same time it connects audio. Also, bluetooth has a habit of going to sleep if music is paused, so then navigation commands dont work, cause they happen faster than bluetooth can wake up.
For navigation without music, bluetooth fails. Aux in works to provide audio without music, but it does not charge, so again Tranzit Link is cleaner, only 1 wire to connect for 2 functions..
no, I dont get paid to shill for them.. just a happy consumer
