Adding a log for E30 Map4 on a 15-100mph run. Felt very good and the IAT's were more ideal than the first few logs that I did. I will also try Map5 tomorrow. CVT was just fine also!
Below are Burgers index for the maps that they offer;
JB4 Map Guide:
Map0: Fully disable JB4
Map1: +3psi peak over stock, default map, suitable for all fuels.
Map2: +4psi peak, suggested for 93 octane or higher
Map3: +6psi peak, suggested for 30% E85
Map4: +7psi peak, suggested for 30% E85 along with bolt on modifications
Map5: +7psi peak, no boost taper, more aggressive version of map4.
Map6: User adjustable by RPM map on user adjustment page, values are peak boost over stock by RPM under heavy throttle.
Map7: Progressive WMI mapping, under development
