1 - 12 of 12 Posts
'04 Colorado, '90 Legacy sedan
I've been looking around quite abit for SS brake lines.
The best price is around $100 from a couple places, Teague's is one of them.
Where is the best price y'all have found?
Superb Moderator, ,
MY12 WRX, MY07 FXT
Make sure they fit your exact model of vehicle. Stop Tech, Goodridge, and another brand are all about the same construction and cost. $100 for a set of four or just the front? Most likely all four. Teague's Auto is a great vendor, bought a lot from Dale Teague. Call him up and ask him about the exact application. Very nice, informative person he is.
I have the brake line mod on my list also, now it's the money, time, wife giving me the allowance...Brian
08 Outback Touring Blue/Grey w:Alpine stereo,corrosion management,front/rear swaybars/endlinks(Whiteline), King Springs, KYB struts,LWT crank pulley,K&N air filter
www.get-primitive.com quoted 125.00 plus 9.50 for a set of Goodridge to fit my 00 Outback.
They say 2000RS Impreza lines will fit my Outback?
2008 Outback 2.5i 5MT
Get the coated stainless ones... not only do they come in fashion colors, but they also don't chew the crap out of the wheel well if they rub a little. I have coated Goodridge lines on my Forester. Paid $100 a couple years ago from www.mastrowrx.com. I see they're a wee bit more expensive now...
2002 WRX MBP
+1 on the coated ones. While if you're using the proper lines, and they're installed correctly, they shouldn't EVER rub a tire, the coating also keeps dirt and stuff out of the braids, which would chew up the inner line as it flexes.
Submod , ,
2000 BMW R1150gs
Right now Import Replacement Parts has a discount on Goodridge G-Stops, Brembo rotors, various pads, kits and other stuff over at NAIOC for members. I ordered the G-Stops yesterday for $99+shipping and will order some Brembo slotted (NO FLAMES PLEASE) rotors for $390 (all four) toward the end of the month. If you order online type in "NASIOC DISCOUNT" in the order discount area on the site.
FYI: I had to order the G-Stops advertised for the "1992-2001 Subaru Impreza 2WD & 4WD w/ Rear Disc for all models Including Outback, Part number: 24212" for my 2004 OBw even though it doesn't advertise for that model/year. However the stock lines for mine are the exact same part number as for the 2001 so they will fit.
Cheers!
Subh
Submod , ,
2000 BMW R1150gs
It's the 4 piece kit and I will definitely report back.
Cheers!
Subh
True... it should NEVER rub a tire... I was talking about rubbing on the inside of the wheel well. I haven't looked at the OBK line routing but on the Forester it swings up and out a bit and could potentially rub against the body.
While you're replacing those lines, swap your brake fluid with some ATE SuperBlue too cuz it's da bomb!
00 Outback wagon 03 VDC wagon 18 Touring 3.6 white
As a FYI just tried the discount code from Import Replacement Parts and says no longer active.
Submod , ,
2000 BMW R1150gs
Call them. I bet they will honour it.
1 - 12 of 12 Posts
