2008 H4SO 4AT VDC 235000km, Eastern Ontario, Canada
While making a list of the fluids I'll need for my 2008 2.5i 4EAT Outback I noticed a discrepancy between the Owners Manual and the Warranty/Maintenance Booklet.
The Owner's Manual recommends DOT 3 or 4 brake fluid. While the Warranty/Maintenance Booklet says only DOT 6 brake fluid should be used.
Any consensus on which is correct?
Discussion Starter #2
Nevermind.
Wikipedia suggests DOT 6 brake fluid does not exist, so I assume that was a typo in the Warranty/Maintenance Booklet. Going with DOT 4 for now.
From the US Service Manual, 2008:
489331
Your Canadian spec Outback is built in the same assembly plant as mine, and I doubt it's any different on fluid specs, other that taking your coolant freezing protection level a bit lower.
