1 - 7 of 7 Posts
Subaru Outback 2010 2.5L
Hi,
Where can I get a new outer hatch panel?
Mine got broken. Attempting to fix with fibre glass epoxy from behind.:frown2::frown2:
Would love some help.
I live in Canada.
Local dealer for new part. Also check US-based internet dealers for price and shipping cost. (Depending on cost, consider shipping to a border location such as Ogdensburg NY where you can pick it up.) Or, for a used panel, check local recycling yards (Some have pick-and-pull days) or a recycling network such as https://www.carparts.com/ .
Discussion Starter #3 (Edited)
Part Number
Thanks for the response, I'll look into those things. Does anyone have a part #? :)
For now I'm using fibre glass and epoxy on the backside.
Check subaruonlineparts - as far as I know, the numbers they list are Subaru numbers.
HOWEVER - after buying a new one, you will also have the expense of getting it painted to match correctly - and then it will never fade at the same rate over the years since it will not be the same paint.
Of course, you could always have it painted in a contrasting color, like satin black.
Fixed it with fibre glass. Looks okay. Friend and I are going to do a proper job a little later. :)
I also found the part at my local dealer if I want a new one, but it will be several parts in one kit costing about $375CAD. I think I'll go with the fix.
I need to remove that same piece, would you be able to tell me how you removed it or where I might find instructions?
Thank you.
1 - 7 of 7 Posts
