I downloaded the btSsm app on my phone hoping to get more info than torque could get me. During my first drive with it i noticed a little icon at the top, that apparently is a knock indicator.
The car seems to drive fine, I cannot feel anything strange. it only knocks at higher throttle inputs, if i drive gentle it seems fine.
Car is a 07 with the 2.5 N/A engine.
KNOCK DETECTED at 2017-09-23 06:35:03 PM
AFR: 15.7
Boost (psi): 0.00
Coolant (degC): 87
FKC (deg): -1.05
FLKC (deg): 0.00
Injector PW (ms): 12.0
Intake (degC): 33
Load (g/rev): 1.07
MAF (g/s): 40.01
Oil (degC): 92
RPM: 2254
Speed (mph): 17.4
Throttle plate (%): 96.9
Timing (deg): 19.0
Is this something I should be immediately concerned about?? I can try different gas, but it will take a few days to empty the tank. I'm a bit freaked out because i just did my head gaskets about 500km ago, but again, I haven't used this app before and nothing feels different. no dash light, fuel milage is the same etc..
What do you wise people here think??
AFR: 15.7
Boost (psi): 0.00
Coolant (degC): 87
FKC (deg): -1.05
FLKC (deg): 0.00
Intake (degC): 33
Load (g/rev): 1.07
MAF (g/s): 40.01
Oil (degC): 92
RPM: 2254
Speed (mph): 17.4
Timing (deg): 19.0
