Hi all - I recently purchased a 2000 Outback (manual trans) with 175,000 miles on it. It seemed to run fine for a few weeks but I had some issues that came up after the Check Engine light came on. I read the codes and replaced the Throttle Position Sensor and the Neutral Safety switch.
Unfortunately I now get random lurching/bucking when driving the car. The car starts fine but when I'm going into gear and letting off the clutch it seems to lose all power and acts like it wants to die out. I put the clutch back in, and sometimes it'll start acting right. Other times I just have to park it for a while and try again.
I read through the previous posts on this issue and didn't see any resolution listed. I will be performing the following maintenance on the vehicle but want to know if anyone has any more input on what I should be fixing:
1) Full tune-up (cables & wires)
2) Oil change
3) Coolant flush
4) Trans fluid replacement
5) Differential fluid replacement
6) Air Filter replacement
7) PCV Valve
2) Oil change
3) Coolant flush
7) PCV Valve
