1 - 8 of 8 Posts
'18 station wagon
Can I glue this down or do I need to remove the whole pad and retape it?
Any recommendations for glue/tape? TIA!
Super Moderator
Thread here:
Remove. Clean. And use 3m automotive double sided strips. Sadly I’ve had to have mine reinstalled a dozen times starting on day one on my ‘18 Outback.
Yep...that 3M tape is great stuff...you can stick sh!t to ice cubes with it.
VHB in particular is the 3M tape you’d want to use. There’s a foam variant as well as a thinner celo tape style variant. I’ve used that on led ribbon that would warm up enough to release the adhesive of lesser tapes, and the foam variant for attaching solid surfaces, rougher surfaces, mirror caps, all sorts of stuff. It’s probably what was originally used. Dig out what you can, wipe the surface clean with an alcohol wipe, then slide the VHB In there
edit, you can get small rolls on Amazon, and McMaster has it as well but I’ve only ever looked for larger rolls there
'18 OB Touring 3.6R Wilderness Green
Any idea what's causing yours to come off? Do you live in extremely hot area? I also have an 18 3.6 touring and haven't had any issues.
The 3M VHB tape is ridiculously strong - essentially permanent.
It may have put on without properly cleaning the surface first. Over time that little bit of dirt has made it let go...?
1 - 8 of 8 Posts
