Hi all, 2000 Subaru outback 2.5 SOHC Did a timing belt change with all idler pulleys and waterpump including drive shaft and both camshaft seals replaced.
Now I am selling like an oil burning while driving. I do see a slight bit of oil the timing belt cover on the right camshaft side. I am perplexed. I pressed the new seals on using socket tools. The only thing I can think of is either the seal is bad or maybe I pressed it on to far. It seemed to bottom out, like i put in all the way in it could go. Not sure if that is a good thing or bad thing. Either way, I do have what seems to be a slight oil leak on that side. Any help would be much appreciated.
Thanks,
Gary
Thanks,
Gary
