I'm a lazy ******* and saw something on the brake port. This is my JDM engine and ports are reversed. Can I switch sides by simply swapping the open port with the plug.
2005 Outback VDC limited 3.0r
it sort of looks that way, try it on your old engine? Worst case you run a longer hose. Or just swap the intake manifold over which seems to be the most common way of dealing with it.
2007 3.0R Outback 5EAT SI-Drive, Push Start JDM 130k km
i think a few people have tried to swap these without luck, there's also the option to use a longer brake vacuum hose
I'd avoid the longer hose unless it's reinforced (like fuel injection hose); would hate to have reduced brake power due to a collapsed vacuum line.
Try the plug swap, otherwise swap intakes and don't be lazy. :haha:
I had to keep my manifold. The JDM engines manifold underside had an egr system while mine has a block off plate.
