Fresh Out of Outbacks!
There's a common adjustment for the entire assembly, so aiming the assembly correctly will put both high and low beams in the right spot.
If it seems like the beam changed between your old bulbs and the current ones, go back and make sure they're seated correctly. The reflectors are very precise- if the bulb is off its seat by even a millimeter you'll get reduced output, weird beam angle etc.
Meh.
I has wagons.
Pray tell, what model of horseless carriage are we discussing here?
They've made plenty of them over the past century I gather.
Sorry.. it's a '17 Outback Premium and now I see the high and low beams are adjusted together.
Thank you, I'll try small adjustments without getting the low beams too high.
moved thread, updated title
