1 - 13 of 13 Posts
Checking to see if anyone has run into this problem and found a resolution. When filling gas tank, the nozzle would click off every 5 seconds as if the tank was full, even though I knew it was not. Called dealer, they couldn't get us in for a month, so went to local mechanic. His diagnosis was fuel filler line, he replaced and problem was still there (his credit, he did not charge me- if anyone needs an honest mechanic in Northern Virginia, LMK). Convinced dealer to look at it, they replaced the charcoal filter and said problem was fixed, I had to pick up after hours, went to fill up gas and still same problem. 2012 Outback 2.5L
Anyone encounter similar problem? Any guidance? Thanks in advance
03 H6 OBW & 06 WRX Sportwagon
details on car? miles, new to you, quality of prior care, present condition, how is it used, aftermarket mods, any work or wrecks before the above problem started?
2018 Outback 3.6R Limited; 2" LP Aventure lift, LPA skid plates and small bumper guard, diff breather relocation, subframe skids; Motegi MR118 17x8et32 wheels; Yakima LoadWarrior with extension; ARB
My guess is that the nozzle of the gas pump is into the filler neck at an angle such that the shutoff is activated due to the gas flowing out or splashing back. Pull the pump handle out a very small amount and see if that allows it to continue flowing until full.
2019 2.5i Premium w/Eyesight, "Wilderness Green Metallic"
I've had that happen when I left the engine running while trying to fuel.
the venting system is quite complex and there are multiple possible failure areas.
Any guidance?
The drain valve on the charcoal canister can cause that problem if it's blocked or otherwise not open. There are ways to confirm if it, or the canister, are bad other than just replacing the whole assembly, but that requires time. As this is not an uncommon fault, I would believe they just replaced it, without first verifying and probably didn't take the car out to a gas station afterwards to see if the fuel could be added to the tank without the pump shutting off.
The work order would/should have described the problem. If they said the described problem "is fixed" and it isn't, they should make it right. I'd bring the car back to the dealer. If they're doubtful, perhaps go out to a gas station with a shop representative and demonstrate.
about 51k miles, it was new to us, well taken care of, mostly highway driving, no modifications or wrecks.
The dealership needs to re-visit the problem as mentioned above.
My MIL had to have the fuel tank replaced on her Forester. Some internal valves seem to have become gummy/stuck from sitting unused a lot.
BTW - according to the TIME side of the maintenance schedule, the car will soon need a timing belt system service.
2014 Subaru Outback 2.5 Premium
Not in my Outback but in my Silverado it was the same issue and replacing the charcoal canister and line fixed it.
2000 & 2002 Outback Wagon EJ251/Auto + 2004 Outback LL Bean EZ30/Auto + 1996 Legacy Outback Wagon EJ22/5sp + 2008 Outback Wagon EJ253/Auto + 2004 Legacy Sedan 35th Anniv. EJ251/Auto (not OB) + 2005 O
I've had this issue before and it turned out to be the vent valve on the tank charcoal filter. It only did it when the car was nearly empty and had been driven highway speeds for a while. My wife would wait till it cooled down and then it would vent and allow the car to be filled. Spiders had built a web in the vent.
Reactions: 1 Lucky Texan
yeah, a bunch of Mazdas were PLAGUED by the spider web blockages in the past.
you could try pulling hoses off the canister when filling, make note of which hose's disconnection improves the problem and trace from there. If NO hose disconnection helps, problem could be in the tank.
BTW, even though it's a 2012 model and past the 3/36 factory warranty, this is part of the emissions system. Depending upon where you live, it might have up to 10 years of warranty coverage on such issues.
Same gas station every time?
Some stations deliver their fuel at a higher rate than others, which will cause the fuel to foam more, causing the pump to shut off quickly, Try delivering at a slower rate and see what happens - if it continues to shut off prematurely, then yea, there is a venting problem.
1 - 13 of 13 Posts
