No modification of any kind needed, I just plugged it in. The size of the assembly is such that I was able to use the included peel+stick to stick it in (there's a kind of a "shelf" of sorts inside the light fixture). Hard to describe, but if you pop the cover off the cargo light fixture, you'll see what I mean. I will try to remember to snap a couple more photos.In the past people have reported having to modify/trim for install. Any problems or is it plug-n-play? What about excessive heat? I too am interested in this mod.
Ah, fair point! It's not so much the LED as the circuit to regulate current that are probably poorly designed / manufactured in those cases, too!Cheap LEDs have been known for getting too hot, even hotter than their incandescent cousins.
Good LEDs run quite cool.
I just installed them. Easy to do and they're a much brighter white light than the dim yellow light from the factory light bulbs.PUTCO® - Subaru Outback 2011-2013 Interior Dome Light Replacement LED Bulbs
Anyone tried these before? I wouldn't mind a little more light in the cargo area as well.
960 Lumen 12000k LED assembly for $6.30:
24-5630 SMD LED White Light Car Indoor Lamp (T10 / SV85 / BA9S 12W 12000K 960-Lumen DC 12V) - Free Shipping - DealExtreme
FIts inside the light fixture just fine, puts out a lot of bright white light. The bulb adapter showed up broken and I had to re-solder it, but the assembly itself is well made. Overall I'm pretty happy with it. I tried to take comparison photos, but cameras mostly do light-leveling so it's hard to really tell. It's brighter, I know that much!
The Putco kit (p/n 980721) contains all 4 LEDs. You got me curious about the temps, so I turned on the center and cargo lights and left them on for about 15 minutes.Anyone know what are the replacements for the center dome and two front lights? Same bulb/adapter or a different one for the middle and the fronts? I would like to go all LED in the cabin if these LEDs don't run hot.
It's REALLY white. Not blue at all.The price is definitely right for this particular mod, but the color is not. 12000K? No thanks batman...
Se7enLC, is the color really white? Or is it really blued out?...
Exactly. The light is only on when I have the rear hatch open, and I want to see EVERYTHING back there as well as possible. I was basically shopping to get as much light as I could get for under 13WLike the LED mods for heat, power, and longevity. Don't really like the soft glow of the stock hatch light. If you need a light back there, it probably ain't for the mood.
Especially if you consider that a large portion of the cost is stepping down from 12V. If car makers actually switch to LEDs throughout, they could do all the LED driving in one place, and just have simple LED bulb assemblies at all the fixtures.Nice price on the link. When are auto manufacturers going to do away with incandescent lights in the interior? Cost should be down to make them affordable for the rear light assemblies on most vehicles IMO.
It takes a long time to ship, but once I get the replacement for this broken one, I'll be able to tell if it was a one-off failure or a design problem.Just the one issue with the solder on an adapter would make me wonder about the wiring popping off. My solder skills are shite.
The center dome and map lights are "festoon" style. The front two are both 5W and the dome is 8W, IIRC. I bought some bulbs for those spots as well, but they haven't arrived yet, so I didn't review them. I intentionally downsized the map light to be only 0.5W so that it wouldn't kill a battery if left on accidentally. Once I get those bulbs I'll try them out and review them as well.Anyone know what are the replacements for the center dome and two front lights? Same bulb/adapter or a different one for the middle and the fronts? I would like to go all LED in the cabin if these LEDs don't run hot.
So are those temps with the LEDs, or the stock bulbs, then? Did you take the measurements with the covers on or off? I only have a cheap harbour freight thermometer, but I'm sure it'll be accurate enough for this.The Putco kit (p/n 980721) contains all 4 LEDs. You got me curious about the temps, so I turned on the center and cargo lights and left them on for about 15 minutes.
The temps are for the Putco LEDs with the lens/covers left on. I tried measurements holding the thermometer at different lengths from the fixtures. The highest measure temp was from about an inch away directly at the diodes, with them on and immediately after turning them off. These LEDs didn't seem to add much heat, so I'm guessing their current draw is also fairly low compared to the factory incandescent bulbs. Best of both worlds: lots of light with little current draw or heat generated.So are those temps with the LEDs, or the stock bulbs, then? Did you take the measurements with the covers on or off? I only have a cheap harbour freight thermometer, but I'm sure it'll be accurate enough for this.
