'07 outback
... 10 year anniversary, time to shampoo carpet of my '07 green bean!
With little effort, it came out perfect. I am beside myself, it looks showroom new. Such high quality material, just two treatments necessary, it's one of the easiest interior fabrics I've ever detailed.
The most difficult interior I've ever detailed: my '04 Prius required several treatments, working my butt off over a long, arduous three day weekend. Trial and error, using my Prius as a Guinea pig, what follows is an optimal formula I narrowed down, in practice and preparation for detailing irreplaceable fabrics of my vintage '88 AW11 show winner.
Optimal for OEM Subaru carpet, doing what follows, you are in for a pleasant surprise:
I n g r e d i e n t s :
5 Squirts - Dawn Dish Soap
1/4 cup - Oxy (e.g., always steeply discounted at the Costco)
3/4 gallon - very hot water (dial your water heater to max temp)
1 - synthetic sponge
1 can - Arm & Hammer FOAM Carpet "Deodorizer" (very hard to find)
D i r e c t i o n s :
Cockpit only:
1). Remove seats (optional) -
2). Add dish soap and Oxy to your bucket, half filled, very hot water (very).
- e.g., by the time you get the bucket out to the car, your Oxy's sufficiently dissolved and suspended, into your suds; you'll have perfect temperature water to shampoo, into your carpet -
3). Plunge your sponge into suds; squeeze from the sponge just enough fluid so it doesn't drip -
3). Gently work the sponge, slowly into the carpet, until consistently saturated -
- e.g., tell-tail indication you've screwed up, undissolved oxy particles appearing in your carpet; don't be a dimwit; follow instruction; dump the bucket; start over -
4). Repeat steps 3 & 4, working systematically, beginning in your passenger footwhel, working clockwise around the interior compartment, finishing in your driver's footwhel; do not (NOT) start on the driver's side! -
5). Let it sit a couple hours -
- e.g., if the carpet's in decent shape, don't be afraid to go in with a second treatment, black interiors clean up nicely the first try; a second and third treatment will likely be necessary on beige interiors.
6). Start in with your wet'-n-dry vac -
- e.g., do NOT use your best gal's Dyson for this; be prepared to spend an hour, diligently vacuuming until carpet is lightly damp; pay particular attention to corners and crevasses; go very slowly and very gently; never race or thrash the hand attachment of your vacuum nozzle across your fabric;
7). Overnight, leave the doors opened; sunroof retracted -
- e.g., garage the car; plug the charger onto your battery, overnight.
8). Next morning, generously shoot your foam deodorizer; sponge it in -
- e.g., key emphasis on the words, FOAM and DEODORIZER; do not substitute foam carpet "cleaner"; never-never-never put a powdered carpet deodorizer, to a motor vehicle interior!
9). Once dry, thoroughly vacuum -
- e.g., for this, you can use your best gal's Dyson, if you need to; in the event you've determined powdered carpet deodorizer was once applied to your vehicle, the aforementioned steps are sufficient to fully ameliorate it.
10). Ratchet in your seats to OEM spec with your torque wrench. Enjoy your beautiful interior like it once was, when she rolled off the showroom floor!
Best,
~ Samuel, '07 Green Bean
Wouldn't it be easier to use a good set of all weather mats and vacuum the carpet more often than once every 10 years........>:)
Reactions: Richard Pare
2005 Legacy Outback 2.5i
Thanks for the tips! My new 2005 Outback's carpet is pretty nasty, and I needed something more than light auto interior cleaning shortcuts.
Why no powder carpet deodorizers in auto interiors?
