1 - 2 of 2 Posts
2008 Outback 2.5l
I'm posting a solution to problem I had with my 2008 OB 6-stacker CD player (GX-204KH) as it wasn't that easy to find online.
The problem was that the CD player would not eject the CDs when the eject button was pressed, and seemed to get stuck in this mode, not letting you eject or play CDs.
The solution is to disconnect the battery for about 15 minutes, then reconnect the battery, then restart the engine. I found that the after I reconnected the battery, I could no longer even select the CD mode or the AUX mode. After I restarted the engine, all these faults cleared.
I hope this helps anyone with a similar issue. Unsure what the root-cause is but it helps to un-stick the system and get you playing CDs again....until the fault comes back ;)
2008 Outback 2.5l
Discussion Starter #2
This CD problem came back after I recharged my battery about a year later.
I disconnected the battery overnight and the system came good !?!? I don’t understand how this works, and how long it will be good for, but it’s for me going for now...worth a shot!
1 - 2 of 2 Posts
