Okay, about a week ago I acquired another 2001 Outback Wagon 2.5 M/T for very little money. S/he has 152k and I got it from the original owner. It's in reasonable shape, but was the victim of repair work by people who just didn't understand Subaru's, or the concept of torque, proper fitting parts, reattachment of main battery grounds, inspecting their work, etc. The car came with all the service records, but it's more like an indictment than an asset. Over the weekend I replaced spark plugs, valve cover gaskets, and timing belt (all original
Another problem I was aware of was the CEL. After reading through the FreeSSM thread, I installed the program and ordered a VAG-COM cable, which arrived today. I went out and read the car's ECU, and the only code in it was P0052, HO2S Heater Control Circuit High, Bank2 Sensor1. All fine and dandy, but the code is for an H6 engine, as the H4 has but one bank. A Subaru bulletin, 11-92-08, says it's the bank2 A/F sensor, or front O2 sensor. Again, fine, but I (should) have only 1 bank on this car. I reset the code and it immediately came back when I started the car. I'm going to tear into the wiring over the weekend, but has anyone else seen coding like this?
JP
