Would you have a tutorial or anything as to how to remove the center arm rest assembly?I think someone is going to have to pull the console and get a good look at the underside. It probably snaps into the back of the console but there's not much room on the "seam" for an interior tool to pry it off. How ever it's attached it feels pretty solid. For me the risk of damage working blind is greater than the difficulty removing the entire console. YMMV.
Bingo... thank you, thank you, thank you....it is attached with screws from the inside. I installed the 110v outlet and had to take it apart. Here is the link to the instructions from sol parts.
https://www.subaruonlineparts.com/r...goto=subaruonlineparts.com/pdf/H7110AJ100.pdf
-Mike.
Huh, never thought about that before. On the one hand, yeah - all the inverters I've seen have ground, too. But on the other hand - how? There is no ground!Also is it me or is it weird the port is missing the ground prong? All inverters I've had before had it.
If unbolting or removing the passengers seat for the installation of this product it will be necessary
to re-calibrate the Occupant Detection System.
Seems like it's just the passenger seat, most likely to activate and deactivate the passenger airbag. Still doesn't make sense why, but nonetheless.
And I'm still confused about what you are removing lol. I need to see some pics when you are done.
