Changing the Automatic Transmission Fluid (ATF) in the Subaru Outback 4EAT is no harder than changing the standard engine oil. No joke.
Items required:
AT Filter (I got mine at the dealer. While you are there pick up some of the drain plug washers if you do not already have some from changing the oil.)
A socket wrench with a 17mm head.
A drain pan to catch the oil.
The Transmission Fluid. Five quarts should be enough. I use Mobil 1 ATF and can't say if its worth it or not. The transmission uses Dexron III/Mercon fluid. Available at any auto parts store, or even Walmart. Or right here on Amazon: https://amzn.to/2lfFtZp
Step 1: Toss a pan under the transmission pan. It is located about a foot behind your engine oil pan. If you cant change your own oil you might want to leave this to someone else.
Step 2: Unscrew the 17mm bolt on the drain of the transmission pan.
Items required:
