i changed the plugs in my H6 last night, WOW what a poor design flaw.
is there any tips to make this job go alittle faster than 3 hours.
Dar
Dar
Yes. On the driver side, take the battery and washer reservoir out. This makes room to remove the coils.i changed the plugs in my H6 last night, WOW what a poor design flaw.
Dar
Kind of like doing that 6th injector on your Dodge...some jobs are a pain.Oh yeah i did it from the bottom, On the pass side i did put a small port-a-power between the engine and frame and moved it over about 1 inch, that help alot, as well as all the corect tools, i just didn't want to unhook the motor mounts to raise it up, although i probly will the next time.
i think maybe raise it up and scoot it over mite be the way to go.
I heard the new powerstrokes are that way.As someone already mentioned the first step on a head gasket job for some ford powerstroke trucks is #1 "remove the cab"
what were they thinkin.
+1 on this!! I have a '98 Lincoln Navigator; last two spark plugs/coils on each side are so far back under the cowl you can't even see them. When I needed plugs, I waited until a local dealer had a "loss leader" special and let them do it. Coils are starting to die (not unexpected at 270K) so my ground rule is that I will replace 1,2,5 and 6; my mechanic will do 3&4 or 7&8 as one on each side fails. End of rant!!!On Ford stupidity. Have one in the shop now for ignition plugs replacement. 5.4 3 valve POS. The coils were removed and plug ports flooded with PB Blaster and sat for 5 hours. 7 of 8 plugs broke off. This morning, I'm going in to remove the lower portion of the broken plugs. The rear of the engine will be the most difficult because of the placement of the engine. I will probably spend about 3 hours getting them removed and replaced.
Ford is the worst for building a vehicle for maintenance. It's like they are put together as if nothing will ever go wrong and reg scheduled maintenance is labor intensive.
