In most cases, yes. The CEL will normally go out if the fault that originally caused it to turn on isn't detected again (usually in three consecutive driving cycles). However, the code or codes associated with the CEL should remain in the car's computer memory for up to 40 driving cycles, so you should still be able to read the codes for the next while.. . . .can I pull up the oldd error cod ith the light out?
