1 - 16 of 16 Posts
2018 3.6R Limited - Magnetite - LP Adventure lift
Who's done what?
I know some people have done custom vinyl. Anything seems to be a non-permanent solution, as vinyl is probably only good for what, 5 years? maybe 7?
Plasti dip? Im strongly considering this one as it seems the easiest fastest method, that may be more durable than vinyl.
Who's done what for this? I really dislike the look of chrome around the windows.
If you used a vinyl kit, where did you get it?
2018 Limited 2.5i
being as ive used plasti-dip on several vehicles in the past- I would go vinyl. the upkeep on plastidip to me gets old and it fades. plus eventually it bakes onto the plastic and removal becomes a royal PITA. ive used it on wheels, trim(grills/bumper trim) and its always either faded and baked on or I need to go back and touch it up. I feel like vinyl would be more durable
The problem is the application of it.
Ive yet to find a kit of pre cuts. That and having it done at a shop is likely a couple hundred bucks.
My plasti dip seems to have held up well. So far anyway..... If I could find a precut kit Id go vinyl.
'18 2.5i Premium
How hard is it to remove the trim without damaging it? Seems like buying a small roll of vinyl would hold up better than plastidip...
Brucey
'17 3.6
I used this:
https://amzn.to/2Ji68z5
I had to order a second roll because I was just barely short. Best just to order the double roll.
I even made a video because there isn't a lot out there for applying it:
It's held up great. Goes through car washes just fine. I need to re do a section that's my own fault but it peels off if you want.
It may only last "5-7 years" but its a lot less mess, prep, and effort than plastidip. Plastidip is going to look awful in 7 years. It will really look awful in 2. Go look up long term plastidip pictures. It's all awful
I think we should have a concerted effort do describe plastidip as ....awful. (maybe a wikipedia campaign).
and Brucey needs more coffee.
Got it now. Replacing walls in the downstairs bathroom.
interior plumbing in WV? ...
what is this world coming to?....abominable,...against the laws of humanity.
Discussion Starter #10
**** maybe I just get brucey to drive over one state and do all this crap to my car. LOL
forum beach and modification day. :cool:
'18 2.5i Premium
If the trim can be removed and reinstalled easily, have it bead blasted ( or soda-blasted - this is to dull the finish and give the surface some "tooth"), then epoxy paint it.
You could also leave it on the car and carefully Scotchbrite it, then carefully tape and spray it. Whatever epoxy paint you use will need to be UV resistant.
It will be a LOT easier to touch up a painted surface when it gets nicked than vinyl.
2015, Outback, 3.6R, White
Just watched that video Brucey made, great job!!!
I might try the same but with cutting tape. Has anyone tried something similar, but used cutting tape instead of a blade?
Discussion Starter #16
Probably what I am going to do myself, actually.
1 - 16 of 16 Posts
