1 - 2 of 2 Posts
Sometime during the summer, I started noticing a very light clicking sound from the frond end that only occurred during slow turns. It got progressively more noticeable over the next few months, turning into a rattling sound on sharp slow turns. I took a look underneath, and saw the driver side outer CV boot was torn. Figured an axle replacement is what I needed. I contacted the nearest Subaru dealer (2 1/2 hours away), and they said they would do the work with just an aftermarket axle. I decided to just get the axle replacement done at a local mechanic.
I finally got the work done last week at the local mechanic. The noise seemed to be gone.. for a few days. Now it's started coming back, nearly as bad as before. It still sounds like it's on the driver's side. I took a peek underneath, and wouldn't you know, the passenger side outer CV boot is nearly gone as well.
Any idea what could be going on here?
- Cheap replacement axle making noise
- Passenger side axle needs replaced
The new axle doesn't seem to be causing any other vibrations or issues, whether stopped or at speed. It's just that the clicking/rattling seems to be coming back.
This is a 1997 OBW with 232k, so I don't want to pour a ton into it. Not mechanically inclined. Thanks for any help?
complaints about typical aftermarket rebuilt axles are very common.
You have other choices. For about $10-$15 more, you can get a new EMPI axle from rockauto or amazon . many people have good luck with those.(including me - so far)
Exchanging your Subaru axles (are these original axles?) with MWE in Colorado is a good way to go
some folks do biz with Raxles.com , seem to have a good reputation.
Find out if the newly installed axle has a warranty.
consider replacing the other side with an EMPI.
you may some time if you need to wait and save up for the next repair. Axles will often go weeks/months while clicking before the actually fail.
others may have additional ideas for you.
1 - 2 of 2 Posts
