I know the climate control could be better in this car, but I have a question about the AC button.
When the climate system is in Full Auto, the AC light is always on. Does this mean that the system actually has the AC on the entire time, or that it's allowed to turn it on if necessary?
For example, in the winter I wouldn't want the AC on at all when it's usually just heating the car, but it's kind of a pain to always go and turn off AC after you adjust any settings.
Most ACC systems I have owned are like this. Annoying. The A/C is on in "full auto" unless the ambient temp outside is less than around 32 degrees (not sure the exact number on the Subaru). This is really annoying if you park your car in a garage in the winter, where it's warmer, then immediately drive outside...the A/C stays on.
The solution is to leave the system on all the time (never push the off button) and turn the A/C off so it runs in "Auto" mode.
2013 Outback Limited 2.5 EyeSight & 2010 Legacy Premium, 2010 OB Limited (traded)
Your logic only applies to older A/C systems. You have a energy saving variable displacement compressor that is always on as long as the engine is running. No clutch, no compressor kicking in and out. Lots of discussion about it somewhere on the forum if you do a search.
