2005, Subaru Outback 3.0r LL BEAN
Ok, so it WAS my transmission that went out:( and the driveline too!
Now I am on the hunt for a transmission for this car!
It is a 2005 Subaru Outback LL BEAN 3.0r 5eat Sportshift
I have been trying to do a lot of research and cannot seem to find a definitive answer, will a legacy GT 5sp auto work on my car? Or will a outback XT 5sp auto work on it?
My BIG question is
Will this tranny from a Liberty bolt up?
I'm worried about needing to locate a new rear diff? Will I need to for any of these trannys?
If I go with the JDM tranny what do I need to do to get it to work with my USDM engine and rear diff?
On your transmission and on the data plate for your car should be a transmission identification number TG5C7CMXXX where the three X's vary. You can check your data plate/transmission and find one with the same identification.
Car-part.com lists only 2005/2006 Model Years as interchangeable.
FYI under your avatar it says you got a 2.5I
and not a 2005 Bean,
if you click the link next to the question mark in my signature you can fix or add.
_______
Libertys are like Legacys.
you maybe isolated to 245-250hp 3.0 outbacks, or JDM lancasters. for differences in gear ratios/ specs, as few will be the exact match.
I would call Subaru Rupair in Colorado and ask if they have a matching one and how much would it be to ship to you.
they can also verify what you should be looking for (at least in the USDM).
2006 Outback Sedan LLBean
Well that pic looks like the same description as yours. 05 3.0. giddy-up!
Sent from my Nexus 6 using Tapatalk
_______
Ok I fixed my Sig from my old Subie to the new one... thank you!
Ok I will give them a jingle and see.
So what is the difference between the JDM and the USDM trannys anyways? Is there something backwards on them? Or anything I need to worry about or custom fab?
