1 - 2 of 2 Posts
2001 Outback 2.5, 2015 Outback w/ Eyesight
2001 Outback, 2.5L I have done everything I know to do but coolant still wont circulate through engine. Has anyone ever had the water ports plugged from deposits and how to you get them cleaned? I have already changed thermostat, water pump, all belts, head gaskets, radiator, flushed and new coolant. Thanks
what are the symptoms, what led you to do the work listed? what does the temp gauge indicate? is fluid being pushed into the reservoir and overflowing? did you use a thermostat from the dealer? are the fans working?
1 - 2 of 2 Posts
