2013 XV Crosstrek
Is it recommended to mix the coolant with distilled water even when topping off the overflow reservoir? I topped off my reservoir last night after checking the oil, adding windshield washer fluid and routine checking.
So far, my intercooler hood scoop sucked up one leaf, that was it, no birds, UFOs, small children, yet.
Jay
2005 OBXT Ltd 5MT Champagne
Jay H said:
I
Jay
Didn't find an OBS or two in there? :)
No sure about the coolant. I'm guessing that very small quantity of distilled water would be OK, but if it's more then a few ounces, I would add Prestone instead.
2013 XV Crosstrek
So far, it has only gotten to +4 here as a low in NJ... Not living in the Hudson Bay area in Canada or anyplace like that..!
Jay
Subaru Outback 3.0R 05
The second function of engine coolant is anti corrosion for coolant passages and head gasket, diluting the stuff may cause corrosion products to coat the walls and decrease the cooling efficiency in later life. Just a thought.
