I have a 2007 Outback that my wife drives. to preface: She said she was not able to get heat to blow. She walked me through all of the stuff she did (basically turning the knobs numerous times in different configurations) and then at the end she said the heat started blowing and there was smoke blowing out of the vents too.
I drove car to work and found that:
1. the temp gauge didn't move for the first 2.5 miles of driving. Once it started moving it moved pretty quick up to the middle range of temp and then slowly crept higher.
2. If I park and leave the car for 5 minutes and then drive again it the temp gauge will lower as the car cools down but then creep upwards.
3. It got right to the lower line of the "danger" section of the gauge but I would pull over and let it cool down.
4. The coolant was low so I add and it didn't seem to make much of a difference.
5. Even when hot, it didn't blow warm/hot air.
I am thinking that I have a faulty thermostat. Before I begin troubleshooting, is there anything else I should be checking or thinking about? Heater core? Temp door cable?
