1 - 9 of 9 Posts
Hello Crawford Performance Fans!
It’s that time of year again, Group Buy Time!
We will be having a Group Buy for our Air/Oil Separator! - V2 & V3 w/ free installation in Ontario, California!
*More details at the end of this page. Please read the entire post before making a purchase. Thank you. Purchase for 30% OFF Here. Use the code CPAOSGB at checkout.
Share, Share, Share!
The more of your friends and fellow Subaru lovers that sign up for this, the greater the discount for everyone! Feel free to share this post as well as our Facebook and Instagram posts!
Participant List
Discount Pricing is determined based on total number of participants. Discounts start at 15% off and tops out at 30% off retail! We plan to update the customer list once every 24 hours (excluding weekends).
Please visit our website here for Full Participant List and to see what the discount is currently up to!
Product Information
The Crawford Performance Air/Oil Separator (AOS) is the original solution to Subaru's notorious oiling system issues. Although the technology was pre-existing with other vehicle brands such as Porsche, Crawford Performance is the inventor of the first system specifically for Subaru. No other AOS on the market employs the same technology.
• Not a Catch Can - Closed Loop and Maintenance Free
• Reduce Oil Consumption
• Reduce Detonation and Risk of Engine Failure
• Avoid Ringland Failure
• Reduce Fuel Dilution and Subsequent Power Loss
V3 Key Features
• Improved Dual Chamber Design
• Easier and much faster to Install, cuts install cost by 50%
• Right-Hand Drive Compatible
• Utilizes the OEM PVC system making it smog legal and quick to install.
• Does not require Coolant lines due to its mounting location and full use of the PCV system.
V2 Key Features
• Added Coolant Bypass Line to Avoid Condensation
• Can is Heated for Cold Climates and Short Drives
• Bypasses PVC System for a race style system.
How does it work? The built in AOS that comes factory in Subaru Engines is only semi-efficient at stock power levels. Any added power/stress/heat and G-Forces increases the amount of excess oil that ends up in your intake. Due to the fact the oil is heavier than water and you're dealing with a horizontally-opposed engine, the oil can only end up in one place: coating the tops of your pistons. Since oil is naturally combustible, this causes irregularities with the controlled explosion that happens in this environment, subsequently creating multiple explosions. Another word for this is detonation — an engine killer. Stop the oil from ever getting there with the Crawford Air/Oil Separator. Having a secondary system is your fail-safe for detonation that is un-related to a poor tune. You will also consume less oil and help maintain the ultimate mixture in your cylinders to maximize your power output.
These kits include the can itself, and all necessary hoses and fittings to install. The install does take some mechanical knowledge, so we suggest taking your car in to a professional for installation. That being said, we provide step-by-step instructions so that enthusiasts can install the kit at home with a few simple tools.
Model Variations
S0699 = V3 AOS for 2008 - 2014 WRX (EJ Engine)
- Retail: $384.95 | 15%: $327.21 | 20%: $307.96 | 25%: $288.71 | 30%: $269.47
S0699-1 = V3 AOS for 2008 - Present STi (EJ Engine)
SO711 = V3 AOS for 2013 - 2017 Subaru BRZ/Scion FR-S/Toyota GT86 (FA Engine)
- Retail: $319.95 | 15%: 271.96 | 20%: $255.96 | 25%: $239.96 | 30%: $223.97
S0712-1 = V2 AOS for Subaru w/ EJ Engine (Universal Mounts)
S0713-1 = V2 AOS for 2008+ STI with Top Mount Intercooler
S0714-1 = V2 AOS for 2002-2007 WRX/STi with Top Mount Intercooler
S0715-1 = V2 AOS for 2002-2007 WRX/STI with Front Mount Intercooler
S0715-2 = V2 AOS for 2002-2007 WRX/STI w/ Front Mount Intercooler (RH Drive)
S0716-1 = V2 AOS for 2008+ STI w/ Front Mount Intercooler & OEM Turbo Location
S0716-2 = V2 AOS for 2008-2014 STI w/ Front Mount Intercooler & Rotated Turbo
S0717 = V3 AOS for 2015+ WRX / 2014+ Forester XT (DIT)
- Retail: $339.95 | 15%: $288.96 | 20%: $271.96 | 25%: 254.96 | 30%: $237.97
S0718 = V2 AOS for 08-14 WRX; 05-09 LGT/OXT; 07-13 FXT w/ TMIC or FMIC (OEM Turbo Location)
S0718-1 = V2 AOS for 08-14 WRX; 05-09 LGT/OXT; 07-13 FXT w/ FMIC & Rotated Turbo
Details and Duration
The Group Buy starts August 22, 2017 at 12:00PM PST and ends on September 22, 2017 at 12:00PM PST, depending on number of submissions. The Group Buy contains 4 discount tiers: 15%, 20%, 25% and 30%. Just by signing up, you will automatically receive a minimum of 15% OFF! Once 15 deposits have been received, everyone will receive 20% off, 25% off once 30 deposits have been received, and 30% off once 45 deposits have been received.
Shipping & Tax Info
We will have all AOS’s ready to ship the first business day after the Group Buy ends on September 22, 2017, depending on number of submissions. If the maximum discount of 30% is reached, we will begin shipping accordingly. We must receive full payment before we ship! Flat rate shipping to the 48 States with FedEx Ground will be $15. We can ship internationally for an extra fee.
Payment Details
Since the Group Buy has reached 30%, we have created a 30% OFF discount code for you to use at checkout instead of having to deposit $150. The Discount Code is CPAOSGB. One use per customer! Active until September 22nd at 12:00pm. This Group Buy will run across several forums & media sources. Please allow for up to 24 hours for us to update the list. Payment may be sent through either of the following options:
• Through our website: Click Here
• Call (760) 631 - 2927 and pay with any major Credit Card or Debit Card.
Must include the following information:
- Name
- Address
- Phone Number
- Part Number
- Forum & User Name
Master Caster
🖤💔💙 3 Beautiful OBXTs
Now I need to scrape up some cash for Cherry. I designed my own dual system for the other car. But it still has to be emptied, and it is dual cans.
I so want the Crawford AOS....
We had some individuals contact us asking if the Group Buy was still going on.
Yes! It is still going on. It will be going on until September 22nd at 12:00pm. There is no limit on the amount of people who can buy an AOS during the Group Buy. Use the code CPAOSGB at checkout for your instant 30% OFF, no more deposit necessary!
Shipping is going well. All AOS's that have been paid for in full will be shipped out by Friday! We have plenty in stock for anyone who has yet to get there own. Only 10 days left to earn the 30% off! Use code: CPAOSGB at checkout.
- Team Crawford
Master Caster
I wish I had plenty of $. I'd be on board for (2). It's just not in the cards. I do like the little reminders of what I am missing tho.
Sometime in the future maybe. It's a great product.
1 - 9 of 9 Posts
