On my 2001 outback when going over speedbumps or similar, there is a creaking sound from the front end. Just wondering if anyone had experienced this or if it might be a bushing or something that needs to be lubed or one of the plastic trays underneath that is loose.
Superb Moderator, ,
MY12 WRX, MY07 FXT
Usually that can be heard when it gets cooler outside. I think it is the rubber bushings and such on your undercarriage. I've had that prob on other vehicles. Just a bunch of suspension flex going on and the creaks to go with it, mainly in the cold. Where are you geographically? Brian
MY99 3rd Gen Outback GX, 2004 Lexus RX330 Sport Luxury
Creaking over speedhumps is usually sway bar bushings. Lubricating them will usually help.
Winestone color MY2000 Std OBW
Hi All...new to this NG.
I've got the same type of problem when hitting speed bumps and dips but my sound is more like a chirp than a creaking noise. I can't isolate it since it only happens when driving. You all think I've got the same prob and need the similar remedy.
TIA....bgin
My friend's '00 OB with 80k exhibits the same behavior... I take it this is a common problem with Outbacks of that age.
Tokyo's between my toes
2001 Wintergreen Outback 5MT
Mine has had a minor front-end creak for years, it's only occasional, and doesn't seem to cause any harm.
