1 - 20 of 20 Posts
1996 Legacy Wagon
Just bought this car and the cruise control does not work. The light on the switch works when I push it but that's about it. I searched the forum but did not find anything about this other than some people replacing the neutral safety switch. My car won't start unless I push in the clutch pedal so I'm guessing that switch is ok. Has anyone else had non functioning cruise on a 90's model and what did you to fix it? Thanks
· Premium Member
09 C63 AMG, The OBS has a new home.
Contact Dealer
Might try contacting the dealer and asking the parts department what part is commonly replaced, you know, feel em out. See what the service manager has to say.
1996 Legacy Wagon
I was just browsing cruise control parts on ebay and noticed there is a separate ecu for the cruise control. Anyone know where it is on the car and how to test it? The chilton manual is not very helpful. I'll try calling the dealer too but I'm pretty sure they'll just want me to bring the car in which I'd like to avoid.
1996 Legacy Wagon
Some more searching online found similar issues posted but no fixes. My airbag light is on but didn't think to tie it to the cruise control issue. Sound familiar to anyone?
The car has cruise, but it is currently not working due to a broken switch inside the steering column. The switch also controls the airbags, which are also not functioning. The airbag light is lit on the dash.
I am getting a red Airbag warning light on my display. Also my cruise control does not work, maybe related to the
airbag as both are under the steering wheel?
Why does everyone go for the expensive fixes without checking out the simple stuff first. Just because your house has a blown bulb doesnt mean you sell it.
There are serperate brake light switches for the cruise. Usually they are the reason the cruise doesnt work. they need to be adjusted or replaced. There may also be a seperate clutch switch too. Check those first.
You have an airbag under the steering sheel and over the glove box, as well as a bunch of sensors through out the car.
There is a clock spring that is common to both systems, that is easy to repair (read inexpensive). A dealer can pull the codes off the air bag system and determin whats wrong (unless you want to pull the codes yourself). This is a seperate plug from the OBDII, and someone here has the procedures.
nipper
2000 OBS 2.2L
nipper
I agree with nipper. If the car is a 5-speed, check the top of the clutch pedal. Mine was missing a cap to trigger the cruise control switch. The cruise conrtol module thought that my clutch was in the whole time, thus not allowing the module to activate cruise.
I fixed this with a small round sticker (Thick plastic) that came with something else I had lying around. Fixed it for free! I'll try to get a picture for you, I have my camera here with me and my car is out in the lot.
2000 OBS 2.2L
Pictures
Here are the pictures of the fix I did. It shows the clutch both in and out. You can see the white sticker that I put on the pedal to activate the switch.
In this image you can see the thick white plug on the brake pedal.
In this image you can see the plunger of the switch and where it is making contact with the sticker that I put there. I need to get something more robust, it looks as if the switch is damaging the sticker I used.
1996 Legacy Wagon
Discussion Starter · #10 ·
That was indeed the problem , cruise works great now. Thanks so much for replying , I used my cruise on the way home tonight. Cruised right to the hardware store to get some self adhesive rubber cabinet door bumpers to replace what I rigged up earlier.
1998 Legacy Outback AWD 2.5L manual
Thanks again! This fixed my cruise as well! I wrapped electrical tape around that portion of the pedal a couple times.
I keep wondering though....why would it be that way to begin with? Was there a little stopper there at one time that has long since been lost?
1996 Subaru Legacy Outback Wagon; 2.2L; 5-speed
1996 Legacy Cruise Control malfunction
To Davis 61381 - Excellent tip on correcting a cruise control that has electrical power but will not activate when engaged by the cruise control "Set" lever. Thanks for suggesting such a simple repair.:)
1997 Imprezza outback, but they are all basically the came car
cruise problems
Find a wiring diagram. I got one from my local library. Alldata has it.
On Imprezza the control module is just left of the steering column on the backside of the plastic trim. It is easy to check connections to the control module connector. My problem turned out to be a bad set/resume switch.
1 - 20 of 20 Posts
