1 - 20 of 54 Posts
2017 Outback 2.5i
Hi Guys,
Not sure if anyone is interested, but was trying to work out the best way to mount a UHF antenna at the rear of my 2017 Outback.
After lots of drawing's, I finally worked out an end result and had it properly drawn up and laser cut in stainless steel.
Very happy with the result. Let me know what you think.
Cheers,
Pete
nice and clean there, and not mounted to a front fender :smile2:
2018 Outback Touring 3.6R
That looks really nice. But is an exterior antenna really necessary? I've just used the rubber duck on my handheld for years. Naturally, a non-handheld needs an antenna. So forget my question. :D
2016 Tungsten Outback 2.5l Premium w/ES, OP 14, PP #4
Nice job on the mount. Mine is less elegant. I used some 2 in. x 16 ga. material salvaged from the grand daughter's old swing set. Mounted used the fasteners for the cargo tie-downs. Since the tie-down is not grounded I ran a ground wire to the lift gate gas spring mount. Primary use is for my HT if more range is wanted.
205 Outback Limited. 1971 MGB GT, 1965 Austin~Healey, and others
That is a sweet mount.... I wonder if it's big enough to accept a Larson NMO mount for my 2/70 dual band antenna?? as the NMO base needs a 3/4 in hole...………………..
Thanks...
Brigitte
de K7SSC
2017 Outback 2.5i
Discussion Starter #9
Should be fine. would just need to increase the hole using a step drill bit.
2019 Subaru Outback Touring 3.6R Wilderness Green
I'm also interested on buying one of this antenna mount, very neat set up.
How can I buy one of these for my 2019?
2019 Outback Limited 3.6R, crystal white pearl, vanilla interior.
I’m also interested in buying a copy of your mount for my ‘19.
What happened to a group buy?
1 - 20 of 54 Posts
