When you do, check out the videos about doing the rebuilding.I got a quote from Raxles, $250 a piece. A little too much for right now so I’ll reboot and see how it goes.
I watched one video, doesn’t look super fun, but definitely doable.When you do, check out the videos about doing the rebuilding.
Do you mean reboot? Or actual rebuild with new bearings etc?At that mileage, I would remove the whole axle and rebuild it - not at all hard to do, and by doing that you can see if it is starting to show any problems or not.
Basically just clean and regrease everything. However, if the tracks and/or the balls show pitting, it is time to replace the whole assembly - they will run a few thousand miles, but......Do you mean reboot? Or actual rebuild with new bearings etc?
Great, I’ll order some boots, clamps, and get to it if this Oregon rain ever stops on a weekend.Basically just clean and regrease everything. However, if the tracks and/or the balls show pitting, it is time to replace the whole assembly - they will run a few thousand miles, but......
Not really as far as I know ( 40 years of prepping and rebuilding CVs for racing, and so far have never noticed or heard of a problem), but it certainly wouldn't hurt.Yep! Watched a few videos.
Is it important to match up each bearing with its respective slot in the holder? The only rationale I could see is to stay consistent with wear patterns.
Napa HD, and brand new all the way.What do you all like for CV axles? Both of my front boots are torn.
OEM doesn't really seem to be an option. Saw some ok reviews on the Rock Auto/Cardone ones.
Any recommendations?
Thanks!
