Hi Folks,
I am trying to diagnose a vibration my wife's 2012 OB 2.5i CVT has had since about 30,000 miles. I managed to get rid of the very bad one in the front with a new lower control arms that physically had the front of the car moving side to side. The one in the rear has been irritating but overall not a dealbreaker, just a tad bothersome when you can't turn up the radio. New shocks are going in on the rear since I did the fronts and the damping difference is worth the work.
Anyways I did some of the tests on the highway today (changing lanes quickly to stress the inner cv's to see if the vibration increases or decreases) and the outer CV tests of quick accelerations between 10 and 20, 20 and 30, 30 and 40, and then turns listening for a clunk. Nothing on the front much changed.
However I got under the car today and spied on some of the bushings (I learned that subaru no longer sells the rear knuckle bushings themselves anymore, the rat bastards), and did an in/out, up/down, and forward back grip on the cv shafts, and the fronts were nice and tight with absolutely no play, but the rear shafts both moved in and out of the ends with enough room to make an audible clunk, but no other movement in them.
Does this sound like a bad rear CV shaft? Are they supposed to have this much play. All CV shafts are original to the car currently at 76,000mi.
