21 - 40 of 49 Posts
Discussion Starter #22
Does anyone know which of these two it is? Or will I have to get the shop to take out the old one before I get to order it's replacement?
Discussion Starter #23
Good point, for sure. That's a real concern. Thanks.
Maybe I'll see if there's an OEM rebuilt one out there. And I will check car-parts.com.
Cheers.
Brucey
'17 3.6
The one I replaced looked like the second one.
However I'm not sure what one failed on this model. The resistance and code in the ECU should give it away.
Discussion Starter #27
They don't seem to have parts for a 2012 Subaru. Thanks, though.
@toronto78
The P0971 code is related to the AWD transfer solenoid, not the Torque Converter Lock-up Solenoid that your eBay clip in post #21 above is for. I believe that there's some functions on the valve body that use the same type/model of solenoid, but I don't know if these two are interchangeable.
Edit: Solenoid resistance data in an ATRA paper indicates that the AWD transfer solenoid is the only solenoid with a resistance of around 3 Ohms. The others are all higher, suggesting that they are not interchangeable with the AWD solenoid.
Discussion Starter #30
@toronto78
Thank you for noticing that. I think I typed 'TR690 solenoid' and it auto-filled the rest. You just saved me from a terribly embarrassing mistake. Thank you, OBDad.
Discussion Starter #33
So the transmission shop says that it's the 'transfer duty solenoid' in the valve body, The owner of the shop says he's called around and can not find a source for this. I was quoted about $1400 for just the valve body, not installation.
Does anyone have a source for the part I need? It seems all of the ones I find are the torque converter ones. Although one of them is 3.5ohms, so maybe that's what I need? Please help.
Put a separate thread in the Classified forum looking for that solenoid. Someone might have a valve body that was replaced for another problem, but the AWD Solenoid on it might be fine.
Brucey
'17 3.6
I believe it's this one:
Discussion Starter #36
Sweet. Thanks. I believe that will be the one I order. I showed it to the guy at the shop. He wasn't as optimistic as I'd hoped, but what the ****. I expect this will work and it beats a $1400 valve body.
I'll let you know how it goes.
Cheers.
Discussion Starter #38
Well that's great news. Hopefully btsnhos does and is able to help.
The link is the same for me, sort of just a screen shot. And when I take the item # from the URL it brings up the listing, but the part is out of stock. I've written the seller to see if it's coming back, but nothing yet.
BUT I took the part numbers and replacement part numbers from the listing that's put of stock and cross-referenced them with each other and came up with a bunch that are listed as torque converter lock-up solenoids. From that I looked at just the ones that are 3.5ohms and I will pick from that group.
The AWD switch solenoid is the only one on the valve body that's 3.5ohms. So I'm guessing a little, but feel confident that it's the one I need.
Although now I'll wait for btsnhos.
Thanks. This has really perked up my day.
Cheers.
Discussion Starter #40
For those of you who don't want to follow a link from a stranger's post on a web forum...
487307
21 - 40 of 49 Posts
