The short answer is Yes. Most machinists immerse cylinder heads to clean them, The chemical used is safe for metals, but not nesessarily the material on the seals. It is always a good idea to replace the valve stem seals anytime the heads are removed to save you the cost of having to remove them again in a very short time, to address a buring oil or smoking conditions.
