1 - 12 of 12 Posts
2003 LL Bean Outback H6 and 2019 Outback Base
I have a dent in the drivers side rear quarter panel. Its about 1/4 inch deep and the size of a cantalope....
Should I PULL it out with suction ?.......or go from the inside out ?
appreciate your help. I will try to upload photo today
Try a suction cup that size of a dent should work with the suction cup. I have one that is up high where the crease is behind the rear window near the roof line. Too **** small for a good suction cup which means one of these days when I have time to futz with it I'll be taking the inside plastic panel off to see if there is any slight chance I might fit something in the area to pop it out from the back side.
If there are no creases, grab a plunger and a bucket.
Do a little research first you don't want to be to aggressive you could end up cracking the paint. I've used this technique successfully just do a little homework and common sense. Hope this can be of some use!
I know I have, and will be trying that on the large dimple I've turned into a small warble on my hatch. I did the 'paintless' method by using a 1/2" breaker bar handle with a couple of old socks wrapped around the end, then pushed on the back via the holes behind the interior trim. I'm going to gradually try to nudge out some of the various dings on my car using a variety of methods.
That hairdryer compressed air is incredible !!!! Thanks Subyluv..!!!!
I am trying to figure how the heck it works though. Would hate to damage anything when paint is perfect..... Too bad I didnt have an " old" car to practice/ try on....maybe I'll look around at my friends....
Appreciate all the help
Thank you to ALL !!!
Discussion Starter · #11 ·
Trying to locate a suction cup about a 2 inch diameter...went to pepboys ..nothing !!
Any other places I should check ?
'03 L L Bean - LOVE IT!!
Hope it can be of help, that's what we are all here for. Good luck!
Subyluv,
I tried this today with no success....however, it was cool here in CT, so I'm wondering if I should have waited? I left the blowdryer on for over a minute, sprayed the air and it did look EXACTLY like the video. Only no pop. :(
Do you think I should have waited until it was warmer? The dent is so smooth, we figured it should have come right out.
And, of course, I did this while my husband wasn't home. If he tries it in a few days and it works.....I'll be annoyed!! ;)
Any suggestions welcome!! Thanks!!
Elle
1 - 12 of 12 Posts
