1 - 15 of 15 Posts
Let me start by saying part of this may just be inadequacy of not doing maintenance myself. My dad taught my brother and I how to do some basic regular maintenance (changing brake shoes, changing oil, small stuff) and rarely paid for maintenance. I don't have a garage or the tools to do much of this stuff, but I still feel bad for not doing it myself.
Just dropped my '15 Outback off at a very well-respected independent Subi specific repair shop in town for the 60K service. Quoted price before I left was about $560. I get a call in the shuttle on the way to the office that they finished the inspection and on top of the typical stuff for the service interval (spark plugs, belt check, brake check, oil change, etc) they wanted to replace the battery tie down ($75), replace the cabin air filter ($88), and replace the front and rear diff fluid ($can't remember exactly what he said...maybe like $120?) for a new grand total of like $860 ish.
I'm a little peeved they want to do an oil change, since I still had at least 1000 miles to go until I actually needed on (the sticker from them is still on the windshield) but whatever. Now I don't have to come back. It doesn't sound like anything but the spark plugs really needed to be changed from the inspection (as far as belts, brakes, etc. go) so it really feels like I paid them a **** ton of money to look at my car. $88 for a filter is absurd. I'm kicking myself since I know it needed to be changed (haven't changed it in like 35K miles) and probably isn't hard. The battery tie down....my last battery had to be replaced for corrosion because it wouldn't hold a charge when I got some hail damaged fixed last summer, so I guess I'm ok with that if it saves me from having to replace the battery again. Diff fluid...I'm not sure. I drive in the mountains a lot, and in the summer do a lot of camping off forest roads with a bunch of stuff in the back, so maybe...
I don't know. Just frustrated that this place is independent and super well-respected in the area, but seems to be no better than a dealership in pricing... Now I remember why I skip service intervals.
Your issue was asking for "60k service". Cabin air filter is super easy, no need to charge $88 for that. Diffs for $120 seem reasonable, unless that's each. Ask for a-la-carte, not as the interval package...
If I was in your position I will fix everything that you are comportable to fix then take it to the shop, of course they will tell you everything that it need to be change because you ask for 60K service they know that you can't do those simple things. Like the cabin filter you can buy the filter for less than $20 then install in less than 5 minutes. I'm just saying and my .02 cent.
Yes, the filter (engine air filter probably?) is overpriced.
Yes, the battery hold down parts are overpriced. But an untethered battery can do a lot of damage to your engine compartment in an accident or even a minor fender bender, well out of proportion to the accident itself. It needed to be replaced if it was compromised by corrosion.
Yes, the fluids were due to be changed, other than engine oil.
Live and learn. And do these things yourself next time!
And BTW - skipping service intervals because of overpriced service providers is being, well, rather penny wise and pound foolish.
That's what I keep trying to tell myself. Live and learn and now they're done, start fresh and be on top of the maintenance.
Though I did just get a call to approve another hour of labor because the spark plugs are being super difficult to come out. The guy said it's like they were glued in. More than anything, I just want to know if this place is worthy of the constant praise it receives. Sounds like it's no better than a dealer.
If they were not pulled at 30k miles for inspection, that may well be the case. FWIW, a 60k spark plug replacement interval doesn't mean you should forego inspecting them at 30k for any issues; it simply means that under normal wear and tear conditions, they are capable of going 60k.
Probably not. But keep on asking around, and even post to this forum in a new thread; there are a lot of Colorado people on board here.
I would not approve another labor hour, if they are suppose to know subies so well spark plugs aren't hard and to say they need an extra hour because they are stuck in seems like they are ripping you off bad. Even for a mechanic 88 is unacceptable to change a filter, they paid 15.00 max for the part and it will take their lowest paid mech 5 minutes of their time to change it so either they have one **** of a mark up on parts or the worlds highest labor rates. I would tell them to F off on the extra hour of labor but they better still change those plugs out. Don't go back their live and learn don't let them get you again.
Discussion Starter #10
This wouldn't be Super Rupair by chance?
Yep. Had some good experiences there with simple stuff (oil change, alignment), but then that. Now, I just noticed my right rear tire is cupping again (why I went in for alignment ~8K miles ago) so now I'm wondering if the alignment is off again or if at 61K miles, my shocks and struts need to be replaced...
Funny this came back up...
I took my 2011 in for service on Saturday. Oil change, diff service and rear brakes. The service advisor asked if I just wanted the 90K mile service since I was getting the oil change and diff service. He agreed with my response "why would I pay an outrageous amount for the 90K service if 90% of the 'inspect' items are going to be done anyway". We also had a brief discussion about the outrageous air filter charge when they do the labor anyway in order to show me and reinstall when I refuse, he didn't even bring mine out to show me. He wouldn't budge on doing a tire rotation for free, even though 2 of the tires would be off the vehicle anyway. The place I got my tires from will do the rotation for free...
Discussion Starter #12
Ya, definitely felt silly for specifically calling out the 60K mile service. Seems like most of it was just "checking" things and nothing really needed doing except the things I had to pay for on top of it.
Side note, they DIDN'T catch (or at least didn't tell me) about the pretty bad cupping on the tire. Now I don't know who to believe, them (who said it was an alignment issue 8K miles ago) or Big O Tires, who says the struts need to be replaced. Given that the wear is the exact same on a different tire, I'm going with struts, and I'm a little peeved that Super Rupair recommended the alignment before.
Now I've asked for strut quotes from a couple of places, both with OEM and if I source the parts myself (leaning this way, as I want Rallitek springs to give some lift). We'll see...
Super Moderator
If you have the tools/time/skill to DIY, you can get preassembled struts and springs from Rallitek. KYB (OEM supplier) struts with Rallitek springs. Spendy, but not any more than I paid to have my stuff replaced at a local shop WITHOUT springs.
Mal had 1 strut start leaking fluid badly and another start leaking lightly not long after I bought him. Normally, I source my own parts, but I needed him road trip ready for a 1500 mile trip within a few days of starting to creak and leave dribbles of hydraulic oil everywhere I parked....so that wasn't an option. The $1400 bill for new struts, mounts, and boots installed however, made me regret not renting a car and getting the Rallitek kit to install when I got back.
Discussion Starter #14
Ya, I've watched a few videos....still a little intimidating, plus I only have very basic tools, no jack, no stands, nothing.
And yes, I'd love to grab the Rallitek pre-assembled struts, but the 2.25" lifted ones are on back order until mid-June! I'm driving from CO to Moab this weekend and not thrilled that nothing is going to get done before I leave, let alone waiting another month. I've reached out to a few places to get quotes...if it's crazy expensive, maybe it's worth it to give it a shot myself...
Have been towing a 450# trailer with gear on and off for 3 years. Had a bunch of sag and didn't really feel like my 2011 was off, but hated said sag. My buddy offered to help, along with $40 labor charge at local garage to remove and replace springs. I went with the 1.4 Rallitek rear lift, as I'm towing a 5x8 uhaul from NC to Denver, next week. We'll see how the towing goes. Every Subee I've ever owned has had front end chatter from day one, whether brand spanking new or 10 yrs old - bad struts, old struts, crappy struts...who knows. Maybe I'll go with the half inch lift or OEM front soon?
Sent from my SM-N960U using Tapatalk
1 - 15 of 15 Posts
