1 - 17 of 17 Posts
1) Avoid anything by ROADGEAR® -- they're pure crap.
2) The most important feature is a good chuck that seals quickly & reliably.
3) I have yet to find a digital gauge with a satisfactory chuck.
A gauge that bleeds off a lot of air every time you use it is worse-than-worthless.
Banned
2007 Outback XT Ltd
If you buy a $10 gauge you can expect $10 results, meaning that they tend to be harder to use and the accuracy is not guaranteed. I use a high quality armored round gauge with extension hose - $38 from Amazon. Griots Garage carries the exact same gauge with a hokey vinyl soft case for $60....
Look for a gauge that reads to a tenth of a psi. The reason is that if it reads only to the nearest pound, one tire might be 31.5 psi and the others might be 32.5 psi, and the gauge would read the same! You definitely want to be able to get your tires very close to the same pressure for best handling.
I had to change the battery in mine after maybe eight years of use - it is easy and uses a cheap button cell. The lighted display tends to use up the battery, but it is nice in a dim garage or at night.
I used to use high quality mechanical (dial type) gauges, but they are fragile and you never know if they are reading correctly. If you drop one, it may start reading three or four pounds off. Not good. The digital gauges are pretty much bullet proof.
John Davies
Spokane WA USA
Fresh Out of Outbacks!
I happened to notice that consumer reports did a comparison of a bunch of tire gauges. I couldn't tell you what they picked as a winner, but the most interesting detail to me was that quality is all over the place, even within brands. So if you hear about a good one, make sure you learn which model it is, going by brand alone is not good enough.
2013 OB 2.5i Premium/DDD Graphite Gray Metallic OP#2 Weathertec Window Deflectors
I bought a Slime it reads in 1/2 pounds also, I had a accutire battery went out on me 8 yrs. old. Mine is a straight on and of don't like the ones with a 90 or so bend.
Sears has a nice one but it was to much for me, it talks has a flashlight etc. I have a Slim
I think the ones sears are Accutire but it's up to you.
2016 outback premium
bleed feature
Accutire MS-5510B Racing Tire Gauge : Amazon.com : Automotive
John Davies
Spokane WA USA
Thanks I like the bleed feature of this one. Is it a screw or button you push
Looks like the 2 most recommended on Consumer Reports are the
Accutire MS-4400B
Accutire MS-4021B
Slime did the worst of the 14 they tested - digital 20074 and Dial type 20048 did particularly poorly.
They noted that keeping the guage in the glove box can lead to mis-readings, as it doesnt work as accurately as if it is at room temp.
They also note that nitrogen in tires still escapes - though slightly slower than air.
Banned
2007 Outback XT Ltd
It's a spring loaded push button, and it's slow. That is good for when you are close to the desired pressure, but for faster bleed, you can push the chuck on and off the stem to release more air.
John Davies
Spokane WA USA
03 Outback H6 base
While I like the racing one shown above, I was looking for one to carry in the glove box. None of the digital ones I tried had the bleed feature and were a pain to reset to "0" when rechecking for desired pressure.
I settled on this one from Slime. It's not digital but seals great and has a relief button. I like it even though I wanted digital.....
2005 3.0 R n totaled
I prefer analog, like OldStyle has. I have a very accurate gauge with all the features described above, but it's not digital. It has a rubber housing cover and has a Camel logo on it. Not sure, what brand it is as I have it for almost 30 years now. Most folks on racing circuits still use the analog tire gauges - from what I have seen, walking through the pits.
Banned
2007 Outback XT Ltd
]I settled on this one from Slime. It's not digital but seals great and has a relief button. I like it even though I wanted digital.....
Link to gauge
Sorry to burst your bubble, but any analog gauge that cheap is almost certainly inaccurate. Tho any gauge is better than no gauge.
John Davies
Spokane WA USA
03 Outback H6 base
John Davies
Spokane WA USA
Burst away! Guess I got lucky... No difference in the reading between the pressure at my tire shop and the gauge I bought and decided to keep....
Been using pencil "stick" analog gauges for 45yrs. Some are good others not so much. Always check the accuracy of any new gauge against a known good gauge.
I'm sure you have had different results.
Same here, except 50+ years. Ergonomically, pencils-type gauges
are the absolute best: compact, pocketable, one-hand operation,
no battery failures, and inherently hold-the-reading until "reset."
Bottom line: check all 4 tires in less than half the time -- without
bleeding-off more than a mosquito-fart of air.
Easy to check occasionally against an accurate (but leaky-chuck)
digital -- when I'm in the garage with an air compressor handy.
Cheap enough to throw away when they don't measure up.
I have a Sears digital straight on one with an LED "flashlight" which is nice to have when checking the pressure at night. Also has a lighted read out that can be set with a specific pressure for each tire - other than front and rear I'm not sure why it is needed. It does not talk but beeps. It has a bleed feature that stops at the pre-set PSI. It has more the bells and whistles than anyone really needs. But I'm a geek and it checked out accurate against other digital and analog gauges so I like it.
1 - 17 of 17 Posts
