Hi,
I have Defi Racer gauges in the a piller.
Right now I run my tail and marker lights all the time + my fogs. Given how the factory illumination system works the gauges and radio dim when the headlight switch is moved from off to marker lights and is still dimmed when I switch to headlights.
I would like to change this so the dimming only occurs when the the headlights are on.
I have a full wiring diagram but I can't seem to find exactly what I need to do this.
What I would like to do is roll the illumination roller switch to the first notch down which currently dims when the headlight switch is moved from off to marker lights. This end the end this would be changed to when the switch is moved from running lights to headlights.
I hope I was able to explain this well enough. It seems like a minor deal but having constantly dimmed gauges and radio gets annoying during the bright/sunny days.
